Hi all,
I've recently purchased a 4 Runner, and sadly the rear window lift mechanism isn't too healthy. One of the nylon wheels that sit in the channel under the glass is shredded and one of the arms (the other one obviously) that connect into these nylon wheelsr has broken off. I've managed to effect a repair by pairing the working arm with the ok nylon wheel, and patched with other arm with nuts bolts, washers and the shredded wheel. Does anybody know if you can get replacement runners, or indeed create a new one with a nylon wheel and a nut and bolt from something else?
