Im looking at getting some new rubber under ny surf as she seems to prefer to go sideways around corners in the wet, my surf is standard with no suspension mods or lifts (only that the front off side corner is 1 inch higher than the rest, not to sure why as its cold outside
) anyway will i be able to fit 31-10.5 R15 under her without causing any problems and what would be the best tyre to go for, im looking at either General Grabber AT2 or BFGoodrich AT KO
Any thoughts would be apreciated and any idea about the ride height being different on the two sides
Ps Standard wheels with 265x70x15 on at the moment
) anyway will i be able to fit 31-10.5 R15 under her without causing any problems and what would be the best tyre to go for, im looking at either General Grabber AT2 or BFGoodrich AT KOAny thoughts would be apreciated and any idea about the ride height being different on the two sides
disco now gone aswell
