Originally posted by kieran2698
4wd problem engaging
There should be a small vacuum hose (as well as the bigger brake booster one) that comes from the vacuum pump (on the front of the alt) up to a t-piece by the Turbo, then one way goes across the motor to the Shut Down and EGR VSV's, and the other way to the 4wd VSV's. It actually goes to the vacuum resorvoir tank under the front wing first, then back to the VSV's.4x4toys.co.uk - Keeping you on and off the road...
Yeah, if you have a wheel arch liner, you might not see it. The tank is right at the front in the wheel arch, behind the lower part of the headlight panel.Originally posted by kieran2698any diagrams of where the pipe should be heading? under the wing? in the wheel arch is that?
I'd disconnect it, and run the pipe from the T straight to the VSV's while you screwing around testing things, it means you can rule out it leaking while you work on the other stuff. You'll need the motor running to supply vacuum remember.4x4toys.co.uk - Keeping you on and off the road...
