thanks for the replies .i dont think it is the heater motor on this ocasion
.........every peugeot i have owned has that problem.but the v belt sound promising. i have also noticed a slight vibration when this noise happens.i think it is a wheel bearing problem.....to tight ?to slack how do you service or adjust them.......................... ....
noise when cold
Hi Matey,
Are you sure it's coming from the wheel?
I am having this trouble at the moment and I think I have found out what it is.
Next cold morning don't put the heating/fan at full blast.
I've let it idle for 5 mins to warm up on low blow and the noise hasn't appeared. Don't know how to fix it tho. :o)
Leave a comment:
noise when cold
i seem to have a squeeling noise from the front wheel ?i think. when the surf is driven for a few miles it goes away .it is also a intermitant when cold ,sometimes lasts 1 second sometimes 5 seconds .i have only had the problems since the snow last week.i have changed the brake pads yesterday ...........still the same noise.wheel bearings seem ok?.how tight should they be?Tags: None
Leave a comment:
