i seem to have a squeeling noise from the front wheel ?i think. when the surf is driven for a few miles it goes away .it is also a intermitant when cold ,sometimes lasts 1 second sometimes 5 seconds .i have only had the problems since the snow last week.i have changed the brake pads yesterday ...........still the same noise.wheel bearings seem ok?.how tight should they be?
noise when cold
Hi Matey,
Are you sure it's coming from the wheel?
I am having this trouble at the moment and I think I have found out what it is.
Next cold morning don't put the heating/fan at full blast.
I've let it idle for 5 mins to warm up on low blow and the noise hasn't appeared. Don't know how to fix it tho. :o)My Surf's a beauty but needs a turbo!!!
1990 SSR Ltd 2.4
thanks for the replies .i dont think it is the heater motor on this ocasion
.........every peugeot i have owned has that problem.but the v belt sound promising. i have also noticed a slight vibration when this noise happens.i think it is a wheel bearing problem.....to tight ?to slack how do you service or adjust them.......................... ....
