Brake Calipers
  • Brake Calipers
    Changing my front pads today & one of the Pistons popped out & is now siezed. Ive removed caliper & tried to press it back in but it wont Budge.
    BUGGA!
    Any tips on getting this Rectified would be good.
      Any use ?
      or
      this ?
      Trev
        The PISTON has come out too far to push it back using the Disk as leverage
          Silly question time !
          Can you get a pallet knife and a screwdriver blade in there ?
          Thinking of having the knife blade against the piston then lever using the screwdriver.
          Trev
            Trev
            Theres to much Resistance. Ive removed brake pipe & bleed valve & its still tight.
              Ive pushed & pushed. Whacked it with a Hammer on a piece of wood and it wont budge
                I've had success before using a g-clamp to press a piston back in when changing discs.Can't say for sure that it will work on a surf as I haven't had the brakes apart yet.
                The g-clamp I use has a bar rather than the 'wingnut' on the adjuster, which means i can use a large ring spanner to get leverage.
                Rob.
                  You what! The piston should push back in very easily unless you have dislodged the seal and jammed it between the piston and caliper somewhere other than the seal groove.
                    Ooohh, that don't sound good.
                    Rob
                    Still working for the man!
                      JOBS DONE with thanks to Ohsupremebeing Chris. The Piston had popped out but was caught on the edge of the cylinder with some gentle persausion it popped back in.
                        Good
                          Good
                          Can i still have the day off on Monday as i need to pursue a better job
                            time for you to buy chris a Beer then
                            Enjoying Life after Cancer
                            Pops
                              I always treat Chris
