Whilst endeavouring to get the winning lottery ticket I inadvertantly
reversed into a post at local shoppery and have bent the bracket that
holds the wheel, into the tailgate!. Thus denting the tailgate,also
the wheel open position light is permanently on. I can knock the dent out
but how hard is the bracket to 'bend' back?. Is it mild steel and will it bend back using some heat?. I was looking to have an easy day on sunday but have now found something to do!!!.
Mind you ,you should see the post!!!
