Fuel Pump Seals?
  • Fuel Pump Seals?
    Hi,
    My fuel pump has started $$$$ing fuel since I started going 50/50 on veg oil.
    (With me, anything that can go wrong, always does!)
    Anyone know how many 'O' Rings I need to get to completely renew a 2.4 EFI Fuel Pump (Denso)?
    I know Milners do a kit but I want to change them "all" when I have the pump out to save future problems.
    Also, do I need a new gasket or anything else?
    Can these 'O' Rings be sourced anywhere else or just Milners?
    I read a few threads that said B&Q sell them in a big assorted bag but are these suitable?
    Cheers!
    Gary
    If it's just the top seal it can be done in-situ (in the milner kit) and you will also need a o ring for the sensor (not in the kit). I have had the o rings done under the timing covers (also not in the milners kit), this cured my leak BUT it meant taking out the pump...........This is a cambelt out job . Also when you are in there check the water pump is not leaking.
    The next step is to send the pump to a diesel specialist for a refurb ( about £200)
    www.daemon4x4.org
      Mine's started to leak, but NOT the top seal, means pump out and off for refurb
      Have filled up with diesel & no veg, has stopped the leak for now, but sure it will be back
      My other cars a QUAD
      (sv1000spilot on surf forums)
        That depends where it is leaking from
        www.daemon4x4.org
          You can get a new 300 series pump (for the EFI)from Oz for about £200.00 brand new, might be cheaper in the long run.
          Legendmaster fitted one, works well he said
          http://www.toyotasurf.asn.au/forum/v...ic.php?t=12737
          Rob
          Still working for the man!
