Have a 1996 KJN185 3rd generation surf which has a noisey differential, hopefully its just the bearings that require a swap. If the pinion and ring gear are also u/s does anyone know of a supplier where I can get an exchange unit ? Thanks in anticipation
noisey diff
You should have the same 8" diff as 2nd gens, so parts come from the usual sources, Milners, LA Supertrux, Toyota, etc. Lots of options if you get one from the US.
Just check you don't have a LSD or electric locker before ordering stuff.
All you need to know about what diff is in each truck is here....
http://home.4x4wire.com/erik/diffs/#8.254x4toys.co.uk - Keeping you on and off the road...
