hello, i seem to get a vibration when i turn the heater on between cold and hot,goes away when its on cold (at the very bottom limit) and the same when on hot (at its top limit)but in between it vibates,it seems to be right in front of me or is it a rattle from the bonet thanks
strange vibation ?
Originally posted by spudshello, i seem to get a vibration when i turn the heater on between cold and hot,goes away when its on cold (at the very bottom limit) and the same when on hot (at its top limit)but in between it vibates,it seems to be right in front of me or is it a rattle from the bonet thanks
Possible air lock? in the cooling try this http://www.allhead.com.au/cooling.html
Or a rattle as you say - start tearing out the dash - always good funAnother member of the 'A' team
