Hi all. have posted before on this, my 2.4L 4wd wont behave.
have been right through and checked all vacuum pipes, all ok, and I can actually hear the actuator work in both directions so am confident all controls to it are ok.
when I engage 4wd from the electrical button on the shift I hear a whir, followed by a clonk, various switches and relays click etc and for a moment the 4wd light flashes on, but usually drops off again a moment later. the truck doesnt go into 4wd as checked by turning front wheels.
I have tried driving it back and forth a bit but am a little limited in waste (loose) ground here so havent driven that far
But I understood it to be that the 4wd light wont come on until firstly the actuator switch is made, and then the transfer case switch is made by the sleeve sliding across, which must be happening for the light to show in the first place?
and as the sleeve isnt sprung loaded, i.e. actuator has to drive the other way to disengage 4wd i'm a bit confused by this behaviour?
is it the case that i need to go find a field and blast round it in 4wd until something frees itself up in there, or any other suggestions very welcome?
thanks in advance
thanks in advance
![Smilie](https://hiluxsurf.co.uk/core/images/smilies/smile.png)
