For the past few weeks my wife has complained of a buzz/rattle from the transmission tunnel, which goes away if you drive with your hand on the 4wd selector. Finally got around to having a look today, took the gaiters etc off and think I have found the cause - I just don't know what it is !
To the left of the selector rod, just under the edge of the hole in the tunnel, is a small round "top hat" type of thing, about the size of the tip of my little finger. It was loose - spins freely (and rattles !). Won't unscrew/screw up, or pull off. I "isolated" it with some rubber tube, and the rattle is gone - but what is it ? Should it be loose like that ? How do you tighten it ?
