I put milners +20% coils ans a full set of ES 9000's on and the ride is stiffer than with the standard shocks, so if you want a softer ride I'd go for the ES 3000's.
hard ride
Originally posted by plumb bobI put milners +20% coils ans a full set of ES 9000's on and the ride is stiffer than with the standard shocks, so if you want a softer ride I'd go for the ES 3000's.
cheers mate
the shocks are i think 35 pounds each, and as to how big a job it is depends on how handy you are. its not difficult, and if i was you i'd just swap the springs to begin with mate. took me about 3 to 4 hours to swap both rear springs, change the shocks and wind the front up. definatly a diy job if your know one end of a spanner from the otherTeaM BOFA4x4 Mac 2008
www.bofa4x4.com
Originally posted by andrewlee31the shocks are i think 35 pounds each, and as to how big a job it is depends on how handy you are. its not difficult, and if i was you i'd just swap the springs to begin with mate. took me about 3 to 4 hours to swap both rear springs, change the shocks and wind the front up. definatly a diy job if your know one end of a spanner from the other
had a very productive day sorting bad earth problems and re-wiring alarm (as somone had done a s*** job of the wiring and it went up in smoke) today and since speaking with you now notice the shocks even more they will have to be done im also after a rear load cover if you know anyone whos got one going pref with barckets
thanks mate jon
Originally posted by BAV1thanks for that mate i have access to garage facilities so that shouldnt be a problem i dont suppose you know exactly what it is i need both coils and dampers and whether there are any suppliers manchester way
thanks mate jonhttps://www.facebook.com/groups/henpals/
Help Still Needed
Hi All
thanks for all your advice im getting there but i am now thinking of replacing the springs/dampers all round or at least the back as im still getting akick up the a*** when i go over any speed bumps or potholes i'm not to bothered about lifting at all although i do do a lot of camping and take some weight with me if i lift slightly would this help does any one have some dampers and or springs they are getting rid of at a decent price will post pics later as my truck may have been lowered and dont know how this will affect the coil setup
thanks in advance
