3rd Gen Under-Slung Spare Wheel
  • 3rd Gen Under-Slung Spare Wheel
    My 3rd Gen has 265/70R16 tyres fitted to alloy wheels. My under-slung spare however is the original 215/80R16 fitted to a steel rim.
    I really must get a spare to match the rest in case I get a puncture.
    Does anyone know if a 265/70R16 tyre will fit the steel rim? It's a 16" but what about the width?
    & will the 265/70R16 wheel & tyre fit in the under-slug position or will it be to big for the winch system?
    Many Thanks
    Regards
    Lewis
    265/70R16 is the Standard size for a 3rd GEN so changing will be ok
      Thanks marky,
      So I assume the 265/70R16 is a factory option as my spare is a 215/80R16 & that size is printed on an information decal with tyre pressures on the B post.
        As far as im aware 265/70R16 is the Standard size for a 3rd Gen SURF
          Marky,
          I presume your spare is a 265/70R16? is it under-slung as well? Does it protrude quite a lot below the rear bumper?
          Regards
          Lewis
            My spare is rear mounted. Your spare should be the same size as the other 4.
            My 2nd gen had the undermounted one which fit just fine.
              Cheers Marky.
              Nice looking 3rd Gen by the way.
