Any advice folks
Got a 3rd Gen 3.0L Manual and it's just started slipping when in 4th.
Don't think it's a clutch problem as all appears normal in the other gears.
If I accelerate in 4th gear from about 40 MPH the revs rise, but not the speed (bit like having a slipping clutch)
Problem doesn't appear above 50.
Have locked on the hand brake and tried to pull away in each gear. All gears apart from 4th the car tries to pull. In 4th I could almost let the clutch right out (didn't because I was scared of something going bang) .
Any ideas on what the problem (and more importantly) the solution is please.
