ball joint
  • ball joint
    one of my ball joints is creaking like a madman.
    it is very hard to tell if its upper or lower, so, is there any way of telling which one it is or is it a case of doing one and if that doesnt work change the other one?
    many thanks scotty
    Are they greasable?
    Believe it may just be a case of seeing if any move too freely
    Gaz
      good question gizmo,
      i'l have to have a better look to see if there are any grease niplles there.
      cheers scotty
        cheers scotty
        The 2nd Gen ball joints can be greased. You just remove the small bolts that blank off the grease points, one at a time, and fit temporary nipple to insert the grease (Molydbenum-disulfide lithium base chassis grease NLGI No.1 or No.2).
        Brian
