Help! 3ltr auto 1994. 2weeks ago, drove over a log and smashed speed sensor mounted high up offside rear of gearbox. Top of sensor hanging free attached to cable, remainder still in gearbox csting. No apparent problem and surf dove normally except that O/D OFF light flashed regularly when O/D was engaged. After a couple of days g/box stopped changing into 4th or lockup, using only 1 2 & 3 changing up at 18 & 38 mph which is a lot higher than usual for a light throttle. Like it has dropped into some failsafe mechanical mode. A few days later on a longish journey it started working OK again, but went back to 3 the next day. Obtained and fitted new sensor, flashing O/D light went out, but still only 3 gears. During next longer journey, began working again after an hour (kicked in and out about 10 times before settling down), but again next day back to 3 again.Just repeated the journey today but it has stayed in 3 gears. Grrrrrrrrr. Are these two problems related? Anyone got any ideas how I can get my missing gears back?
Cheers. Kev
Cheers. Kev
. Oh - and it seems about 15% lower geared than the 3.0 into the bargain - I had expected any change between the two to be in the axles not the gearbox. So now I have a 'cruising' speed of 50mph instead of 60 !!!
