I presume it was the o/d light you were watching for the code and not the engine check light. Just a thought
No i was wathching the engine check light as i did a search on here and it says to watch the engine check light.If i was supposed to check the o/d light i will try this tomorrow.Thanks
You watch the engine check light for engine related problems and the O/D on light for gearbox problems. Hopefully you will get a result this time. Best of luck
Ok i have done the flash test and it now shows codes 61 and 62 but cant find what they relate to so any suggestions would be helpfull.
Dave
Somewhere on here or could be the Aussi site there is a list of codes.
Have you checked the selenoids? these seem to be the cause of most gearbox probs
Dave
Here you go mate
61 defective no2 speed sensor (in ATM) or severed wire harness or short circuit
62 severed no1 selenoid or short circuit or severed wire harness
Sorry but i have not had the chance to get to the garage as yet. Cant find the time or someone that will get me back home as the garage is about 35/40 miles away.
