if you have the switch then when it is pressed a green light will come on on the dash on the bottom right to let you know it's on the hard setting.unless the shocks have been changed be for after market ones then the switch won't work
Thanks for the info Richard. Can't find any button that corresponds to your description. I have the idle up button, one below that [a round rocker switch with a small red LED in it] and thats it.
Thanks,
Shab.
so do you get the the light on the dash illuminate for the hard/soft suspension when its pressed?
