Finally got to fit my roller blind for the cargo area today.I previously got the blind thru ebay, and later sourced the required fittings the same way.
Fitting was very straightforward, once the side panels were removed, there were clearly marked dotted lines showing where they needed to be cut to allow mounting of the fittings. Cut them out, refitted the panels, the roller blind fittings and blind. Job done, total time was about an hour from start to finish.
Finally, some security for the junk in the back.
