Truck is a 2WD 1995 Hilux pickup. I've had it a year and always had the spare wheel in the back as the crane that holds it underneath was a solid piece of rust. I picked up a new one witha couple of other bits from a breakers' yard but I can't seem to get the wheel onto it. It looks like the plate on the end of the chain should be passed through the wheel and locates on the other side, then you wind it up off the road into place, but the plate is too big to go through the centre hole. Am I missing something? Perhaps it's off a 4WD and the hub hole is bigger? Any ideas?
Thanks a lot guys/guyesses
