Smokey Starting
  • Smokey Starting
    BTW.. Like the new forum
    Anyway, been driving for about a week after having new head fitted now when starting in the morning it takes a few goes to start her up, when it does start there is a lot of smoke coming fron the exhaust.
    After the initial start of the day it is fine , it is not smoking excessivly and starts instantly, untill it is left overnight agian.
    When it first happend i was quite low on fuel (But not in the red) , and was thinking that the fuel/Injectors may be full of gunk because of this , so have put some redex in. I understand from previous posts that this can take a few tanks to make a difference , but am paronoid that it is somthing else.
    Any ideas?
    Thanks in advance
    Darren
    Any ideas?
    Thanks in advance
    Darren
    Mines a bit like it since the new head, but then I know that my Injectors are cattled so no surprise there. Yes it does often take a few tanks to clean the injectors and fuel system out so at least give it 3 tanks. Also put a full bottle of Redex in 1/4 tank, not the measure they tell you. The recommended measure is just for regular use to keep things clean rather than for doing a system cleanout.
      if you want to clean the injectors take your filter off tip half the diesel out then top it back up with redex and put it back on, then give it a blast
      [size=5][/size]
        Any ideas?
        Thanks in advance
        Darren
        I had the same trouble when my head was replaced. It took the garage about 3 attempts to fix the problem. My glow plugs and injectors were OK, but a broken wire somewhere along the line meant they were'nt all getting current to them. It took an auto electrician to suss it out. If you think you've got a smokey start now, wait till the cold, damp morningas arrive!!! If your injectors are clogged you'll get black smoke all the time.
        Pete
          Thanks for your replies...
          Just popped out to look further in to this problem and think i have found the answer.
          The Glow plug fuse has blown.
          Also i noticed that there was no fuel heater fuse should there be?
            Another product to use to clean out the system is 44K. Just pull the engine side hose off the fuel filter and put it into the can. Then start the engine and run it through 'till the can is empty. Shut the engine off, refit the fuel line and start it up. Leave it running on Idle up for 5 mins. This should clear out any deposits....
              I've heard great things about this 44K stuff from other people. So who's going to publish a picture of the fuel filter in a 2.4 so I can work out what to do & where to put it ?
              Jim
                Jim
                for ems & jim good innit this edit.......at last
                [size=5][/size]
                  another good product is called forte', p**ses all over redex info here http://www.asc-software.com/mall/ASC...uct-745803.stm
                  [size=5][/size]
                    The instructions say to put it in the tank, but this dilutes it to much. My mechanic told me to go with the fuel filter method, BUT..... this is at your own risk.... I'm just passing on info
                      I've just used Forte, as it was recommended highly by Roughtrax, poured it straight in to the filter when I changed it, and primed, and running sweetly
                        New Head -> smokey start
                        Mine has/had the same problem. After head they changed 2 glow plugs, still hard to start, then a autoelectrician found a broken wire, fixed that, but still it starts with a small cloud of white smoke. Should look for the fuse of the fuel heater. Where does it(fuse/fuel heater) live?
                        Paul - NZ
                        '91 2.4 EFI TD SSR-X
                        [COLOR=darkslateblue]Paul - NZ[/COLOR]
                          if a diesel doesn't start immediatley, there will be some smoke when it eventually starts, as it will be v rich at first due to the unburnt fuel during starting, another possibility is, (i didn't really believe this until i tried it), the battery has to be 100%. i changed mine both recently and the difference is incredible , and it now starts quicker than my works van (2002 transit Direct injection diesel) starts within 1 revolution.
                          [COLOR=red]Simon [/COLOR] '91 2.4td ssr-x
