I think the end has snapped off the cable that runs through the cog on the sunroof movement motor - I've had the motor out and the cable end is sitting just next the cog, but not touching it. The motor works OK but the cable is now either too short or has been pulled through the wrong way and out of the cog.
How can I remove this cable? It looks like I need to dismantle the entire roof to get it out. The headlining appears to run the full length of the vehicle also....
Is this a common fault?
