I've searched the forum for a "ringing" noise but can't find an answer for one like this.
Have found one on the 2nd gen and with problems with worn bronze bushes on the driveshafts, but not on the 3rd gen and I think my noise is different anyway!
The noise starts as soon as you move, you can only hear it with the windows down. It apears to be coming from both sides at the front and sounds like a "triangle" being dragged along the ground and it increases with road speed.
Tried looking at the usual things like exhaust brackets and loose engine bash plates but no luck so far.
Any help or advise appreiciated.
Thanks
Thanks
so I can clean it again [/center]
its not comming from the engine or the breakes, it only does it above 10 mph sounds like a "triangle" being dragged along the ground and it increases with road speed also when i hit a bump it does change a bit.
