I have just changed my 2.4 for a 1995 3.0L. This was advertised as having ABS. The only other vehicle I have owned with ABS had an ABS warning light that came on with the ignition and then went off to show that all was well. I can see no similar light on the dash of the truck. Does this mean that the truck does not have ABS? Is there any easy way to check other than stamping on the brakes in wet weather?
It also interested me that there are no SSR -x or similar markings on the truck. My 2.4 SSR-X had a heater for the rear passengers but the 3.0L does not. As a result of this the centre arm-rest has the top cubby hole and a lower one as well - more useful than the rear heater. Does this help anyones suggest the model?
Keep on trucking,
Keith
Keep on trucking,
Keith
