Does anyone have any advice for how to change the two bronze bushes in the front hubs? I'm going to give it a go this weekend and was wondering if there was any tips from anyone....
Bronze bushes
Originally posted by MattRDoes anyone have any advice for how to change the two bronze bushes in the front hubs? I'm going to give it a go this weekend and was wondering if there was any tips from anyone....
You may find that the rubber seal on the inner side of the hub has become worn. If so its that that has let dirt in or the grease out causing the steel shaft to rub on the brass bushes. You may get away with cleaning them up or to be safe get yourself a replacement.
The bushes come out pretty easy, long screw driver or punch to knock them out, give everything a good clean, fit new bushes and greae up.
When you fit the new ones place an old one on top of it to hammer it home, saves burring the new ones.Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
Originally posted by KoiYou may find that the rubber seal on the inner side of the hub has become worn. If so its that that has let dirt in or the grease out causing the steel shaft to rub on the brass bushes. You may get away with cleaning them up or to be safe get yourself a replacement.
How many miles would you expect to get out of a set of bushes?
Originally posted by MattROK thanks, do you have the part number for the seals? Also, what is the best grease to use?
How many miles would you expect to get out of a set of bushes?Say not always what you know, but always know what you say.
My 4x4
My choice
Back off
