Steering Rack "Clamping"? during a Track Rod Change
  • Steering Rack "Clamping"? during a Track Rod Change
    Morning Gents,
    I'm looking to change the Steering Track rods on my Surf (the current ones are seized on the adjuster, and putting heat on will be erm, tricky), and a note on a the Milner 4x4 website mentioned that the steering rack must be clamped down during the process?
    Could anyone advise on how to clamp it down please? (I'm not familiar with the process, as its always been landrovers for me)
    Also, I've got prices from Milner 4x4 and Roughtrax for the parts, but does anyone have any experience of which is better? presumably they have a common source?
    thanks in advance.
    Paul.
    Hi Folks,
    As a matter of feedback, I spoke to Milner off road about the "Clamping", and their advice was that it doesn't need clamping per se, simply that you are not to apply a turning force to the steering rack, it is designed for linear travel not rotational.
    I've now changed the tie rods/track rods on my KZN185 now, and had it tracked, as it was toeing out quite badly.
    Hopefully this is of use to anyone in the future.
    cheers, Paul.
