Heater blowing Cold Air FIX
This is a sticky topic.
  • Heater blowing Cold Air FIX
    If you're gonna be a bear... be a Grizzly.
    exactly what i do every year when i renew the coolant. Good write up, Ill add it to the stickies. but id contest the Halfrauds bit however
      well I needed to drive SOMEWHERE to test it!
        a fair point
          Insert hosepipe in either feed or return pipe, and gently increase pressure until its flowing out the other pipe.
          Initially I got very little flow, then dark dirty water came out.
          These are the matrix feed and return pipes on the bulkhead, yes?
            I have a lot of problems with the car after the accident, what to do?
              looks like orig writeup is missing? but i guess its about back flushing with hosepipe?
