hi folks, just fitted a new rear window regulator to the surf because the window wasnt closing properly.
out of interest, it is cheaper to go to your local dealer to get it than it is from millners, as millners buy them from toyota in the first place.
anyway the problem i have now is that when the window is going up it stutters about every three inches. the only cause of this i can see is that there is a tooth missing in the window motor cog.
so, can you just replace this cog or is it a new motor?
am i right in saying that it's the same as a passenger side window motor from a corolla?
is it front or back?
does the year of the corolla have to be the same as my surf?
thanks for any advice, scotty
Nil Illigitimi Carborundum
