As a test to see if front drive-shaft, and front diff-flange assembly is cause of vibration when driving around in my 4runner.
would it be safe to temporarily remove the flange/cover on wheel centre (held on by 6 nuts and cone washers), cover/seal the hub-up to stop dirt getting into bearings, then test drive ??
as this would prevent the drive-shaft on drivers side from turning
I assume drive shafts wouldn't be able to pop-out inwards and circlip would still be in place anyway.
any ideas?
thanks andrew
any ideas?
thanks andrew
