Had the surf for 4 months. As soon as i got it i flushed the rad with speedflush and a hose pipe. And then flushed again for good measure. I changed the thermostat to a new one from milner and refilled with a 60/40 mix of halford long life antifreeze and distilled water. Changed the air fuel and all filter + oil at same time.
All throuth the summer the car has been fine with no sign of problems. The car does about 80 miles per day and goes up some steep hills on the way to work.
Today i was jet washing the car with the engine running and noticed water dripping from the coolant expansion bottle, Switched the engine off and checked the oil for water and there was none. Waited for the temp to cool a little. Checked the water, topped up slightly and drove home. Left the engine running at home and noticed the heaters no longer worked and suspected new air block. Had to refill the system with distilled water.
The problem i have now is tryst. What caused the original overheat? Will it be cured? Is it a sign of the head gasket or head going? Do i sell it and get a 3.0diesel. Opps that reminds me the car is a 2.4TD ssrx 1993.
If anyone has any ideas i would be grateful, and sorry to bore you all with yet another heating/head related issue.
Thanks in anticipation of your help
best regards
Mat
best regards
Mat
