This was one of those disasters that I try to avoid...annoying. The plastic case holding the left wing mirror was knocked out of my surf and the glass shattered. No problem. I ordered another glass. I was expecting the glass to come with the plastic holder as I could see it'd be hard to slot the waffer thin glass in the existing holder... no such luck. After struggling with the glass and holder, it broke, ouch. So in order to help me avoid running up a full service style bill on a left wing mirror glass, does anyone know how the hell you fit the sodding thing?
Wing mirror glass
Yeh - try not to push the edges - put the pressure onto where the holder is - we now have a mirror without electrics and a flappy bit of seal which superglue wouldn't fix but I can't afford the complete new assembly so it takes two of us to get it in the right position b4 driving off!
The dealership were really helpful with instructions though! Hope this helps.
Originally posted by JonDissThis was one of those disasters that I try to avoid...annoying. The plastic case holding the left wing mirror was knocked out of my surf and the glass shattered. No problem. I ordered another glass. I was expecting the glass to come with the plastic holder as I could see it'd be hard to slot the waffer thin glass in the existing holder... no such luck. After struggling with the glass and holder, it broke, ouch. So in order to help me avoid running up a full service style bill on a left wing mirror glass, does anyone know how the hell you fit the sodding thing?
dood where did u get the mirror glass from cos i cant !!!!!! find one anywhere
Originally posted by axelgs1 View PostJon Diss
let me know how you did it
Hi Ed..
I will try the heat gun on Monday when the replacement mirror arrives. Deep down I knew a heat gun was the way to go but I thought I would try it in hot water first. Hot water just dosen't seem to soften it enough for the rubber to lip over. As stated I will post with photos the whole job of replacement as this can be a very costly affair for the un informed on what appears to be a straight forward job.
