Finally got around to replacing my front discs and pads today. Was all going so well until I came to put the last new pad in. I discovered that one of the pistons was seized. No prob I thought and went looking for a larger something or other to lever it back in. Hmm, didn't budge. Off with the caliper again and set about putting 2 small g-clamps on it. Well, 1 clamp broke in half cos I over tightened it and the other clamp wouldn't budge the piston either. Tried scraping some of the rust out from under the dust cover, also tried some wd-40 in the same place. I gave up in the end as it was getting dark and have put one of the old pads back in for now.
So, other than any useful tips on freeing it, has anyone rebuilt or replaced 3rd gen calipers yet? If so, where did you get the parts/calipers from? Neither Milners or Roughtrax list 3rd gen calipers so this might be expensive if I have to go to Toyota!
Oh, and what's the consensus on replacing one at a time or both at the same time?
Rob
Rob
