still trying to sort out shaking 4runner.
got a set of completely different wheels/tyres on - still does it,
so have ruled out wheels and tyre problem,
i just had another go at looking at the rear propshaft. I used a jack agasint rear prop flange to take up slack from diff, and found rear prop u-joint has play, So reckon I need new U joints
I also found rotational play in the yoke&sleeve bit of this prop, towards the front, ie that telescopic bit, there was a slight clunk when i rotated the main prop (sleeve), whilst holding onto the telescopic bit (yoke?)-
could that also cause vibration problems?, and how would I sort that out?
