Does anyone have rear window wiring diag or experience - specifically I want to wire a switch to operate the rear window even when the ignition is off - i.e. wire into the key up/down wires. If anyone has info that may save me a bit of time I would appreciate it.
Reason is: Sometimes when away for weekends I sleep in the back of the Hilux, getting out from the tailgate is tricky cos it means I have to turn the ignition on and use the switch up-front - I want to put a switch in the back that works with the ignition off so I can get in/out without hassle.
