Hey folks. I have a 1991 Surf 4x4 LN130 that has an electrical issue I could use some advise on.
The other day while driving all of the sudden all of the warning lights on the dash came on including the water in fuel, timing belt, battery, A/T Oil Temp, and Brake. A few seconds later the buzzer from the battery warning relay also activated (same buzzer that goes off at the end of the glow plug cycle). They now stay on whenever the vehicle is running. These are the lights that would normally come on when you activate the ignition and then turn off once the vehicle starts.
I removed the battery warning relay and that turned off the buzzer and brake warning light, but everything else stays on.
Anyone have some advice on what this could be? I am suspecting a timer relay somewhere that turns all of these on at ignition activation for testing of the various circuits and bulbs but is now not shutting off the 'test'. But I have no idea what this relay would be or where it is.
Cheers in advance for any assistance.
