Hi, I've found two older posts about this, but the links in one of the posts don't work and just want to check the solution before splashing out.
Symptoms:
Car worked fine then suddenly wouldn't start.
No glow plug light on ignition - car turns over fine but doesn't start.
Is this a problem with the ECU? I've read two threads that sound similar that suggest the ECU!
Any ideas/check before I splash out on a new ECU.
Symptoms:
