I pulled my tank and with effort to avoid breaking anything, my fuel sender was so corroded it broke to pieces. I can still plug in the two prongs the are side by side but the other is still in the body side of the connector
There is a yellow/red, brown/???, and yellow and blue (broken piece). This looks like just a ground from the way it's sitting. Anyone know if it is? If that's the case I'll just snip it before the connector and ground it to the frame. Then rig up something to keep the connector from coming off the sender.
EDIT: Just tested my connectors. The broken one seems to be my 5v reference. I thought maybe I could put a 4Runner sender in but I see the connector is different. I have a parts 4runner but it's in a snowbank and getting the connector off it would be pretty much impossible.
Here's what my sender looks like. I thought about drilling and tapping into the metal on the right as that's where it seems to get the power though but that is probably a bad idea. I'm in Canada so surf parts are nearly impossible to find. If I do somehow get the connector off my parts truck does anyone know if I can wire up a 4Runner sender using that connector and have it read properly?
