I have a automatic ctek charger that I use because I only do 1 mile to work and in the winter with the lights on and blower on my alternator won't keep up so after a week my batteries will start cranking over slower. But what I want to know is when I connect it to one battery will it charge up the other at the same time or are they separate from each other? If they are separate could I join them together with a link wire?
Charging batteries
Originally posted by terratology View PostI have a automatic ctek charger that I use because I only do 1 mile to work and in the winter with the lights on and blower on my alternator won't keep up so after a week my batteries will start cranking over slower. But what I want to know is when I connect it to one battery will it charge up the other at the same time or are they separate from each other? If they are separate could I join them together with a link wire?
Have you checked the alternator output ?
Have you seen what voltage the batteries are at with the engine off?Eat.Sleep.Surf.Repeat.
Would one of these help ?
http://www.amazon.co.uk/Visua-Powere...ef=pd_sim_ce_1
If it was used during the day when the OP parks up at work .Eat.Sleep.Surf.Repeat.
Originally posted by Andy Pandy View PostNo they are a waste of time and money bought an expensive one for motorhome,no good tested it running small dash fan at heat of day in southern france just managed to run it but as sun went over it got slower. No doubt some one will say the greatest thing since sliced bread,each to his own.
My truck generally sits on the drive all week and is normally used at the weekends,so it is at the other end of the battery drain scenario (long periods of no use)as opposed to very short commutes.
Perhaps another part of the solution might be to reduce the electrical load on the vehicle?Eat.Sleep.Surf.Repeat.
It's fine just charge a battery, I have a smaller one we leave in the window of our 7.5T horse lorry and batteries have much more life in them even after months of no-use.
You can either clip it on your battery or re-wire the lighter socket to be live all the time and charge it through that.4x4toys.co.uk - Keeping you on and off the road...
Mine had a problem a while back but it was still on the batteries from Japan.....
Got some Exides a while back and it is back to flick of the switch and she starts fine (fingers crossed)
Plus I have a fully charged Red Top I keep tucked away just in case.Eat.Sleep.Surf.Repeat.
Cheers for all the replies, But tonyn gave me the answer I was looking for! I've seen those solar ones before but theres nothing to regulate the supply so when your battery is fully charged with one of those on it you are slowly but surely frying your battery and shortening the life of it. Your far better off using one of the many smart chargers on the market as they won't overcharge your battery and you don't have to disconnect the battery every time you use it.
