Hi All
I posted on here the other day as my tailgate window goes down randomly. This is not a cure for this but it may help others where their key doesn't operate the tailgate window. On my hilux the key would put the window up but not down. It turns out to be the printed circuit board in the plastic block that is connected to the end of the lock barrel. You will see the circuit strip on the right is worn away. This is the side that makes the connection for the window to open. I will be making a new printed circuit board for it in the next few days and will post picks of it and let you know how it goes.
Mike
Mike
