Well after a few times of not being able to release the ignition key, I have found my sensor on the side of the gearstick is getting temperamental! Sometimes it will release no problem, other times i end up cursing at it and f##king about to try and get it to release, I did find if i flick the button on the top of the stick it does finally release. I have had it apart and cleaned the contacts but to no avail! Is it possible to get another or do i have to find a way around that part of the circuit? any suggestions (apart from sell it)
Gearstick Sensor..
Bugger i've put it it back together now! I'll try and get a picture later mate, If i was to say, it sits at the base of the shift on the drivers side, is white held on with three screws, has three very thin wires out of the base that also go into the multi plug for the shift lock (the relay for the foot on brake before lever will move) would that help?I'M ALWAYS IN THE SH'T, IT'S ONLY THE DEPTH THAT VARIES!!!!!!!!
Originally posted by tonupteabag View PostBugger i've put it it back together now! I'll try and get a picture later mate, If i was to say, it sits at the base of the shift on the drivers side, is white held on with three screws, has three very thin wires out of the base that also go into the multi plug for the shift lock (the relay for the foot on brake before lever will move) would that help?
Alwww.amcbs.webeden.co.uk www.xjrestorations.co.uk
