L shape connector no good?
CB Ariel mounting ideas
Not really. Nothing on the back of the truck is straight or level!
If I decided to weld a bracket onto the swing away wheel carrier frame, would I just have to disconnect the battery's earth? Or will I fry the electrics on the truck?
Cheers,
CURLY
Originally posted by charvell View Postyou can get an angle coupling bit that you can adjust the arial to the angle you want regardless of the mounting position. i got mine from thunderpole
yeah I saw those, and 4x4cb sell them too i beleive, but the mount would look wrong if it was fixed on wonky.
I want the mount to be fixed on however is easiest, in line with the tube, but leaving the flat surface that the ariel mounts to level if poss, soI think i'll just weld a bracket onto the rear wheel frame and stop wingeing about it.. its only for the fooking ariel for gods sake!
Thanks for all your inputs though guys, much appreciated.
I will post some pictures up once it is done so you can see what i was going on about LOL!
Cheers,
CURLY
there was a guy on eblag selling mounts that fitted to the rear wheel carriersof different 4x4s not sure if there wasone for a surf but maybe good to use as a templateOriginally posted by Curly View Postyeah I saw those, and 4x4cb sell them too i beleive, but the mount would look wrong if it was fixed on wonky.
Cheers,
CURLYSWIFT AND BOLD
one of these, if anyone can make one i would be interested
http://cgi.ebay.co.uk/Suzuki-Jimny-A...item2c5d79f2f5SWIFT AND BOLD
Well here's how I ended up mounting my ariel onto my 3rd Gen:
Just need to wait for the rain to stop so I can paint it black, and I might have to earth the wheel carrier to the body too, but I will use the hinge bolt as the earth point.
Cheers,
CURLYLast edited by Curly; 28 June 2011, 19:54.
