Hi all
Neither my rear speakers or antenna are working.
2nd gen 3ltr with a stock head unit.
All the fuses check out and the plugs are still factory.
my searching has turned up 3 likely causes: damaged loom, antenna relay, broken head unit.
Is there anything else it could be and is there a way to bypass the antenna relay to get the amps to work?(I dont listen to the radio anyway)
Thanks
Ollie
Thanks
Ollie
 when I get a new headunit ill wire it up properly.
. The wires on the other side of the plug to the blue ones on your pic are the ones not getting any voltage from the head unit.
