Hi all, been looking round the site and it is impressive. I would like to pick someones brains, I have a 3.0td automatic surf, the kzn185.I have a problem with it, the speedo and rev counter,clock,stereo and most other items, when running, none of the above work and the temp guage goes of the scale, when the brake is pushed, the engine stops.When you turn the ignition off and back on again, everthing works untill you start it and its running. I guess its a relay somewhere but i cant seem to find a dodgy one. It starts and run fine but now it cuts out sometimes when driving.
HELP, its doing my head in. Look forward to your replies.
Cheers. Rob.
Cheers. Rob.
