HELP ME PLEASE
1990 2.4 TD Surf 2L type engine.
Got in this morning, turned key to warm plugs, no problems. Turned to ignition position and starter motor gets through half a turn and then total eletrical power death!! Nothing no relay clicks or anything
No power to any functions - lights, radio, horn, anything!!! Almost as if someone cut leads to battery!!
Checked fuses in right side of drivers footwell and inside engine bay above the offside front wheel, no sign of anything blown. I'm at a total loss on this one.
Only work that has been done on it recently is a fuel pump strip out and overhaul due to leaks (don't know if the garage could have upset something on the electrics) and an oil/filter change (electrics untouched)
Are there any other fuses that could have blown that I don't know about and where are they located?
Any suggestions are most welcome, I'm totalyy immobilised at the moment.
Thanks in advance
Scuddy
(Holding faith in his Surf but only just)
Thanks in advance
Scuddy
