Cranks over just fine but will not start, There is no visible sign of the glow plug light coming on and no audible click from the glow plug timer/relay.
There is no power/signal going into the glow plug relay but when the relay is bridged the glow plugs work and draw current, I have checked the obvious like the fuses etc and they check out ok. Also there is no power to the fuel pump, I have got diesel at the pump inlet but nothing being delivered under engine cranking.
Any suggestions of where to start would be much appreciated.
