I broke the plastic spacer as i was bolting up my glow plug rail live, and tried bolting the live on without it. When I switched the ignition on the glow plug light came on, and there was a fairly loud clicking coming from around the air filter, then it stopped and the glow plug light hasn't come on since. I had time to check the fuse under the bonnet by the battery and that hasn't blown, but something has, so any ideas where to start looking?
Also, there is an earth strap that goes on to a stud on the underside of the inlet manifold. where this earth leaves the loom to join the manifold there is also a live strap that leaves the loom at the same place and is about the same length and size, any ideas where its for?!
Cheers!
oh, its a 2.4 2L-T LN130, just in case thats any help!
Cheers!
