Lights, camera (.?), Overdrive..
  • Lights, camera (.?), Overdrive..
    This is an odd one..
    I was on the dual carriageway recently..pottering along doing close to 70 @ around 2500rpm. It got a bit gloomy so i flicked the sidelights on and the revs jumped up a few 100rpm, turn them off and back down to previous.?
    I then experimented with the overdrive at the same speed and the revs increased around 500rpm upto 3000ish..so it looks driving with the lights on gives me 1/2 overdrive..lol
    Just to note, at lower speeds the lights make no difference to running.
    ahhh..just thought, maybe i should of tested the 'extra power' button..could be linked to that.?
    Sounds like an earthing issue....the extra few amps the sidelights are drawing is causing a voltage drop somewhere.
    as a guess, check both battery connections remake etc...
    __________________
    Back in the day Baby
