The tail gate window on my Surf won't open with the key...
The window works from the switch at the front - window lock is off, and so long as the ignition key is in, the window works from the switch.
Of course, I have to take the key out of the ignition to take it around the back to try it in the lock there.....
How easy is it to get to the switch?
It's on the 'wrong' side of the glass when the tail gate is down, and I don't know how to remove the glass to get at the switch from the inside....
