I have obtained a Rear Fog Light Switch from a 4Runner... by post from a breaker in Shropshire. Fortunatley they have supplied the plug from the wiring loom with a couple of inches of wire.
It has 4 wires - white/black stripe, green/grey band, red/white stripe, red/grey band (the grey bands could be white... poor light + old eyes = not sure!!)
The two red wires appear to be the actual switch, checked with meter... they are the only two that short out when the switch is operated.
I gues one of the others would be a ground and the other might be for backlighting at night?
Are surf switches illuminated at night?
Does anyone have a UK 4Runner manual with wiring diagram who can confirm what each wire is for?
If all else fails I'll poke about with the meter and a battery.
Cheers,
Alan
Cheers,
Alan
 ... it is a latching push button type switch, it could be that the bulb connects to the sidelight cct, providing nigh-time illumination when the switch is not operated... and then when it is operated there may some kind of mechanical shutter allows more light to the little window, or maybe just the fact that the push button is physically closer to the bulb provides the brighter "On" illumination??
